layer 2 etherchannel - Cisco & HP
Apr 15th, 2009
we have 2 switches HP and Cisco and we are trying to bundle the 2 physical links between them into one logical link.
attached the configuration on the cisco switch.
is there anything wrong from my side on the cisco switches ?
any idea what can be the issue that it's not allowing to form the bundle ?
thank you in advance.
Jean
CSCO11167812 Wed, 04/15/2009 - 04:39
Hoi Jean,
How did you configure the links on the HP switch. It could be caused by the native vlan command.
Michel
jeansamarani Wed, 04/15/2009 - 04:43
Hi Michel,
thanks for the quick feedback,
do you mean that there is no need for the native vlan command in this case because the HP switch doesn't behave like a hub.
regards,
CSCO11167812 Wed, 04/15/2009 - 04:52
Hi Jean,
So far I know there is no command on an interface on a HP switch.
Did you use the LACP command also on the HP switch.
I used these command on the cisco switch
interface Port-channel1
switchport trunk allowed vlan 15,150
switchport mode trunk
channel-protocol lacp
channel-group 1 mode active
And this command one on the HP2610
trunk 27-28 trk1 lacp.
Hope to help.
Michel
jeansamarani Wed, 04/15/2009 - 05:01
Hi Michel,
basically we are using the same command,
we will try to remove the switchport trunk native vlan command from cisco.
let's see if it will help.
thanks
