Getting line status with SQL statement
Apr 15th, 2009
Hi there
i am about to write my own ajaxified webapp to monitor several things on CCM (4.2).
Is there by chance any way to get the current line status (idle, busy) with a direct query on the CCM database or is it held in CCM memory only?
For example: reading the CFA destination with "select * from NumPlan where CFADestination"
Thanks in advance!
Martin
irisrios Tue, 04/21/2009 - 11:52
  • Silver, 250 points or more
It may not be possible to query line status directly from CallManager database.
Users can monitor the busy/idle status of directed call park numbers using the Call Park Busy Lamp Field (BLF) buttons.
Jaime Valencia Tue, 04/21/2009 - 12:00
  • Cisco Employee,
  • Hall of Fame,
    2011
line status is not held on DB, only on memory. RIS takes care of that
java
if this helps, please rate
