CSA Install Agent Kit
Apr 15th, 2009
Hi all
I have a question. I need install 1500 agent kits in office, but the domain policy allows the installation of software just from administrator. If I try "Run as" some kits I can install, but some not. How to solve this problem? I have not found this problem in guide.
Anonymous (not verified) Tue, 04/21/2009 - 15:13
Once you build an agent kit on CSA MC, you deliver the generated URL, via email for example, to end users so that they can download and install the Cisco Security Agent. They access the URL to download and then install the kit. This is the recommended method of agent kit distribution. But you may also point users to a URL for the CSA MC system. This URL will allow them to see all kits that are available. That URL is:
If you are pointing users to the "kits" URL and you have multiple agent kits listed here, be sure to tell users which kits to download.
jan.nielsen Wed, 04/22/2009 - 04:21
Are you running a solution with 1500 machines, and no automated installer solution like Altiris or SMS and the likes ?
tsteger1 Wed, 04/22/2009 - 14:15
I believe it still requires Administrator priveleges to install the agent kits no matter how it's delivered.
That's why you need to either impersonate a privileged user or get a distribution tool.
shairolbit Thu, 04/23/2009 - 19:55
hai rrjoas45.
i want ask u?i install CSAMC v5.2 ..when i click link to https:///csamc52/kits installation complet but i dont see flag (agent panel)icon at the host agent .can u give me what hapen on this.
izavertaev Thu, 04/23/2009 - 20:07
Did you restart PC? You create your kit? In which groups you have included your kit?
shairolbit Thu, 04/23/2009 - 20:40
my step..system >group>new>windows>name(test)>desc(test1)>rule override(learn mode)>save>generate rule.
for agent;system>agent kit >new>windows>name(test)>desc(test1)>configure(test and force reboot after install)..
i'm go to agent kit host>URL:https://nameMC/csamc52>click this link >install complet >reboot.
after reboot>i got to start button>all program>i see cisco security agent.but my issus flag at task bar i can't see.
any mistake my installation ..
shairolbit Thu, 04/23/2009 - 23:01
can u give me step by step bacis install,congigure CSAMC and CSA agent ?fyi i new in security network..thank regard u .
izavertaev Fri, 04/24/2009 - 01:03
It will take a long time :) you have a manual about this product?
shairolbit Fri, 04/24/2009 - 01:28
only desktop..i want u see attach file the desktop ..server MC no problem i can see flag at the task bar
izavertaev Fri, 04/24/2009 - 02:12
when you create agent kit, you should associate him with group Desktops (default group in CSA)
