Throughput on Catalyst 3550 FastEthernet port
Apr 15th, 2009
  • Silver, 250 points or more
Is it possible to push 99.06Mbps on a Fast Ethernet interface on a Catalyst 3550? I thought the most traffics you can push through a Fast-Ethernet interface is around 95 or 96Mbps. Apparently, that is not the case:
C3550-lab#sh int f0/3
FastEthernet0/3 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0012.0003.1283 (bia 0012.0003.1283)
Description: Provider-1 NGx e2
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 5/255, rxload 252/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:11:29
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 99063000 bits/sec, 8205 packets/sec
30 second output rate 2157000 bits/sec, 4209 packets/sec
5638620 packets input, 4214107302 bytes, 0 no buffer
Received 0 broadcasts (0 multicast)
0 watchdog, 0 multicast, 0 pause input
2893708 packets output, 185404435 bytes, 0 underruns
C3550-lab#
Comments anyone?
irisrios Tue, 04/21/2009 - 10:53
I think you can push up to 96 Mbps on Fast Ethernet interface.
