Diagnosing backbone traffic/congestion on LAN
Apr 15th, 2009
Hi All,
If you were wating to see how much traffic/congestion was on your enterprise (L3) LAN backbone what are some good ways to do this. I know you can use the usual tools like wireshark, solarwinds, etc... Just curious as some methods used.
Brandon
Giuseppe Larosa Wed, 04/15/2009 - 04:58
Hello Brandon,
you can have nice graphs of MIB variables like ifinoctets ifoutctets drawn by MRTG with a reference line = link speed
it provides graphs in a daily, weekly, mounthly basis so it gives both a baseline and growth trends
see
http://oss.oetiker.ch/mrtg/
So you can trace link usages on all devices and navigate on web pages
Hope to help
Giuseppe
Giuseppe Larosa Wed, 04/15/2009 - 05:07
Hello Brandon,
I think they are similar
both use the
RRDTool's data storage and graphing functionality.
So by having a look at the graphs you could have a vision of link usage over time.
Probably you can also try to create events on devices that send traps when link usage is above a threshold.
This can be a different approach with devices playing an active role but requires additional configuration.
see for example EEM embedded event manager
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_eem_overview_ps6017_TSD_Products_Configuration_Guide_Chapter.html#wp1064328
Hope to help
Giuseppe
