"Write Document Step" - IPCCX5.0
Apr 15th, 2009
I have IPCCX5.0 premium(HA).
I am using the function "Write Document Step" in a CRS script to write a file to CRS server disc.
Can somebody tell, to which directory on CRS server I write the file, so that it automatically gets replicated in the second CRS server also.
RSwartzmiller Wed, 04/15/2009 - 05:26
The directory is C:\Program Files\wfavvid\Documents\user\default, and it already replicates
ra_jeshkalra_2 Wed, 04/15/2009 - 15:58
1.Does this have any storage limitation.. or. I can keep writing files till the time I have free space on hard disk?
2.Does this directory automatically get backed up & restored with Backup & restore.
3. I this affected by IPCCX purge utillity or this is untouched?
Jonathan Schulenberg Wed, 04/15/2009 - 17:26
Actually, I'm pretty sure that the NTFS directory structure is not replicated; the SQL databases are however.
There is a concept of a Document Repository within CCX (db_cra_repository). You can upload documents [files] to it through the CCX Administration interface or through a script. This information is saved to the db_cra_repository SQL database and replicated between the CCX nodes. The engine replicates the contents of this database to local disk at start-up and when you "refresh" the file.
The repository does have a maximum capacity limit which is viewable through the CCX Administration interface when you open the Document Repository.
One thing to note: You must authenticate a user using the User steps before a script will be allowed to upload to the repository as a security precaution. You can do this automatically if you pre-populate the necessary information into variables to supply to the applicable User steps.
PS. Even if that directory is replicated, CCX is migrating to Linux in 8.0 (Q1CY10). I would strongly recommend AGAINST designing anything that writes directly to the local disk.
