issue connecting two router, with T1 controller and serial T1
Answered Question
Apr 15th, 2009
Hi, i want to connect two routers via private line, Provider has installed cable on my both facilities.
on one side of router RTRA, i have controller T1
sh version
Channelized T1/PRI ports
on second side RTRB i have serial T1 ports.
sh version
1 Serial interfaces
both have rj45 like connectors, can any one tell me what would be configuration of controllers on both side?
on RTRA side, i have this configuration
controller T1 0/0
framing sf
clock source internal
linecode ami
channel-group 0 timeslots 1-24 speed 64
what would be on RTRB side?
and what kind of cabl ei should use? provider said to use straight cables.
Correct Answer by paolo bevilacqua about 8 years 2 weeks ago
Straiht cable, but NOT ethernet. T1 cable, should in the box with cards.
Overall Rating: 5 (2 ratings)
Correct Answer
paolo bevilacqua Wed, 04/15/2009 - 06:27
  • Hall of Fame,
    Founding Member
lamav Wed, 04/15/2009 - 07:02
  • Blue, 1500 points or more
Ahmad:
Just a footnote...the T1 pinouts are 1,2,4 and 5.
Victor
