ANI server not starting
Answered Question
Apr 15th, 2009
I am running Campus Manager 5.0.4.
The ANI Server is not starting. The status is "Failed to run" in the Process Management page.
I attached two log files. Tell me if you have an idea.
Julien
Correct Answer by Joe Clarke about 7 years 10 months ago
You will need to reinitialize your ANI database as it contains some bad data. To do this, run the command:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI
Overall Rating: 4.5 (2 ratings)
Joe Clarke Wed, 04/15/2009 - 09:22
This looks like an ani database problem. Please post the output of the pdshow command.
Correct Answer
Joe Clarke Thu, 04/16/2009 - 09:03
julien.pasquier Fri, 04/17/2009 - 00:33
Thanks, that solved the problem.
I need now to rediscover the network the fill the ANI database.
