Fail safe edge router / routers
Apr 15th, 2009
Just wanted some opinions on a fail safe edge router design. using 7500 gear:
A -
Single router, two upstream providers with dual RSP.
B -
Two routers, one upstream provider per router.
Overall Rating: 5 (1 ratings)
lamav Wed, 04/15/2009 - 07:24
Hi:
Two routers would be the better approach. You have equipment redundancy, plus redundant service providers.
Am I missing something?
Victor
Daniel Graham Wed, 04/15/2009 - 07:34
I 100% agree, I just wanted to make sure I wasnt missing something....
Adding to this,
What are your feelings on what I will call a "data center switch design"
Single "end of rack switch" Lets say 6500 with redundant supervisor cards.
or
Two redundant "core" switches, each with a link to each "top of rack switch"
I like the latter, but again just wanted some opinions.
Thanks!
lamav Wed, 04/15/2009 - 07:49
Dan:
I would always go with the dual chassis approach over the single chassis with dual SUPs, if the budget allows. I think its pretty straighforward.
Please rate all helpful posts.
Victor
