WIC and HWIC in a Multilink
Answered Question
Apr 15th, 2009
I have a current T-1 running on a WIC-1DSU-T1-V2. I am planning on getting a second T from the carrier for a mutlilink connection. Any problem mixing the current card with a HWIC-1DSU-T1 ?
I noticed the WIC is going EOL
Correct Answer by thotsaphon about 8 years 1 month ago
BRIAN,
Q. How are these HWICs different from WIC-1DSU-T1-V2, WIC-1T, WIC-2T, and WIC-2A/S?
A. The new HWICs have the same software features as the older WICs. The HWIC-1T has a Cisco Smart Serial connector where the WIC-1T had a DB-60 connector. The front-end NEBS protection of HWIC-1DSU-T1 has also been improved.
Please check out this link.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/qa_c67-490366.html
You should be fine as long as Box can recognize both interfaces. Then go configure multilink functions.
HTH,
Toshi
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 04/15/2009 - 07:27
  • Hall of Fame,
    Founding Member
No, there should not be a problem.
Correct Answer
thotsaphon Wed, 04/15/2009 - 07:30
  • Gold, 750 points or more
BRIAN,
HTH,
Toshi
