Extension Mobility Error [2]
Apr 15th, 2009
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
New cluster setup of CCM 4.3(1) for government customer. Extension Mobility was working.
Applied hardening to servers required by customer, and now Extension Mobility returns "Error [2]" as soon as the extension mobility service is selected. IP Phone agent works fine.
Install is using DC Directory, and not active directory. Have not been able to locate any info on troubleshooting/resolving this.
Any pointers / help appreciated.
Jaime Valencia Wed, 04/15/2009 - 07:38
  • Cisco Employee,
  • Hall of Fame,
    2011
it might be an error with a user not being created in dir or registry, you would need to look at a EM trace to determine if this is the case
java
if this helps, please rate
Clifford McGlamry Wed, 04/15/2009 - 07:49
Not even getting to the point where the user puts in their ID when this happens.
EM trace is a good idea though...
Jaime Valencia Wed, 04/15/2009 - 07:51
  • Cisco Employee,
  • Hall of Fame,
    2011
i'm not referring to the users you need to log in EM, but to the users EM process uses to work which are different
it could be the emAPP user but a trace would tell exactly
java
Clifford McGlamry Wed, 04/15/2009 - 08:03
EM trace is throwing two errors here:
%EMApp-3-UNK:EMAppServlet: Unable to initialize alarms
%EMApp-3-UNK:Unable to find registry entry for AppUserID/Password
But it's not AD Integrated. Not sure what to do here.
Jaime Valencia Wed, 04/15/2009 - 08:12
  • Cisco Employee,
  • Hall of Fame,
    2011
try resetting the ccmsysuser with ccmpwdchanger
java
Clifford McGlamry Wed, 04/15/2009 - 08:19
This is 4.3(1) without AD integration. No such user exists in the system.
Jaime Valencia Wed, 04/15/2009 - 08:46
  • Cisco Employee,
  • Hall of Fame,
    2011
really? open your DCD admin, go to users and let me know
java
Clifford McGlamry Wed, 04/15/2009 - 09:11
Changed the PWD, and restarted both Tomcat and CCM.
Same problem, no change. Am I missing something?
Clifford McGlamry Wed, 04/15/2009 - 09:20
EM trace now shows:
%EMApp-AMAPPSERVLET-7-UNK:Context:/emapp ::URI:/jsp/phone_error1.jsp
Jaime Valencia Wed, 04/15/2009 - 12:57
  • Cisco Employee,
  • Hall of Fame,
    2011
just to make sure, you ran the tool in the PUB, the pwd is only alphanumeric, did you reset IIS???
do you have these keys in registry?
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\Directory
Configuration\AppUsers\CCMSysUser\Password
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems Inc.\Directory Configuration\AppUsers\EMApp
java
