IPSEC Tunnels always UP
Apr 15th, 2009
Hi all,
I've a ASA 5540 and configured a Site-to-Site VPN, but the IPSEC tunnels frequently goes down, and when I ping a remote host, the tunnels go UP.
Is there a way to keep the tunnels always UP?
Overall Rating: 3 (1 ratings)
networker99 Wed, 04/15/2009 - 09:25
You might be able to enter 0 for the idle timeout however not sure if this is possible. Why not just increase the idle timeout?
acomiskey Wed, 04/15/2009 - 09:42
Configure isakmp keepalives on both ends...
securityappliance(config)#tunnel-group x.x.x.x ipsec-attributes
securityappliance(config-tunnel-ipsec)isakmp keepalive threshold 15 retry 10
lrm001c474 Wed, 04/15/2009 - 18:00
Enable dead peer detection with the following group level command:
isakmp keepalive
