NAC Check for Vista Personal Firewall
Apr 15th, 2009
I'm trying to create a new check in NAC to verify Vista's Firewall is enabled. I created a registry check for Windows XP Firewall however it doesn't seem to work with Vista.
Here is the Check I created for XP:
Windows XP Firewall Check
Registry Key:
Registry Value:
If the XP Firewall is on the Value will be = to “1”
any info would be great
greg.washburn Wed, 04/15/2009 - 07:52
It's the same setting for Vista as XP. I would check the same area of the registry for a DomainProfile if you use domain computers. There should be a setting there that defines your area of interest with the same key name and same enabled = 1 and disabled = 0 settings.
