Fast Dial export from CCM4.1
Apr 15th, 2009
If you do not use DMA, is there a way to bring over speed dials, fastdials from CCM4.1 to CUCM7.0 using BAT? I've done the DMA from CM4 and applied the DMA to the install of CM7. Since we are still in the testing process of CM7, changes to users fast dials are not being captured.
Is it possible to pull the data from SQL?
Overall Rating: 5 (1 ratings)
ivillegas Tue, 04/21/2009 - 15:16
  • Silver, 250 points or more
Speed dial numbers are always stored in the CM database, and they are saved in the DMA output tar file to be used for upgrade. DMA backs up both CM database and directory data.
Fast dials are user data, and they are stored in the directory in 4.x. In 7.x, the fast dials are stored in the CM database. This is backup as part of the directory data backup.
Directory does an export for "Fast Dial" entry while migrating from 4.x to 7.x; you can see the entries for the same in the csv file
