Port Security based on Device Type
Apr 15th, 2009
Hi all:
We need to know whether there is any feature or software that allows to block switch ports for type of devices.
For instance, we have some switches for IP phones and we do not want to have PCs connected to those ports.
We know that it can be done using MACs, but, as phones can be moved easily, it implies constant changes on port security.
AxiomConsulting Thu, 04/16/2009 - 12:01
Apologies if I have not understood the original question, however, can you use port security (max MAC / sticky MAC) to ensure only devices that are currently connected are successful, other violations will result in the port being shutdown.
You may want to investigate some 802.1x device authentication
http://www.cisco.com/en/US/products/ps6662/products_ios_protocol_option_home.html
Steve
walter.perera Thu, 04/16/2009 - 12:16
Hi Steve:
Thanks for your reply. The problem to use that option is that users change desks quite often and then change their phones also, therefore it could imply lot of changes in the switches port security as every time the phone changes to a new port, configuration has to be done.
That's why we thought of any command / product that could control which type of device is connected to a switch port.
