ASA: How to allow active directory to traverse outside and inside?
Apr 15th, 2009
I am attempting to get AD to cooperate from a parent domain on the outside of the ASA to a child domain on the inside of the ASA.
So far when I first setup the child domain all is well (assuming because the inside server is initiating the chatter) but after a little while (not sure of time frame) AD stops synching and get errors on the servers about such.
Overall Rating: 3.5 (2 ratings)
Collin Clark Thu, 04/16/2009 - 05:57
This is just off the top of my head, but you'll need LDAP, DNS, and Kerberos opened up. If you want filing browsing, you'll have to open RPC all ports >1024 and 137-139, & 445. You have a couple of other options though. You can use an IPSec tunnel between the two servers and/or RPC over HTTPS.
Hope that helps.
dirkmelvin Thu, 04/16/2009 - 06:33
I will try to illustrate my setup here.
I'll post my configs from both ASAs later today.
dirkmelvin Thu, 04/16/2009 - 11:50
I have attempted this, but all I get when I ping is negotiating IP security.
I think this should be working but I'm obviously missing something.
dirkmelvin Mon, 04/20/2009 - 08:38
Here my 2 configs.
Outside is the ASA connected to Internet, inside is the ASA on the inside interface of the outside ASA.
There are 3 AD servers on the inside interface of the outside ASA, and there are 2 AD servers on the inside interface of the inside ASA. all 5 of these servers need to speak AD to each other.
