Easy asa management question
Answered Question
Apr 15th, 2009
Hi All,
What is the application you can use for managing multiple asa firwall rule bases?
thanks
Correct Answer by darrenj about 8 years 1 month ago
The Cisco Security Manager application can manage multiple firewalls and allows a single rule to be applied to hundreds of devices simultaneously. Check it out at:
http://www.cisco.com/en/US/products/ps6498/index.html
Overall Rating: 5 (1 ratings)
John Blakley Wed, 04/15/2009 - 12:30
  • Purple, 4500 points or more
SSH, Telnet or ASDM. ASDM is stored on the firewall, and you get to it by https://
There's no application that I'm aware of that will allow you to connect to multiple firewalls and manage all of the rulesets via a centralized management console.
HTH,
John
