RSM CAT5509 IOS Upgrade
Apr 15th, 2009
I will be upgrading IOS image on RSM Cat5509 from 11.2 version to 12.2 . Do i also need to upgrade bootloader image?
also what is the significance of bootloader image in the boot process?
boot bootldr < >
boot system < >
Overall Rating: 4 (1 ratings)
glen.grant Wed, 04/15/2009 - 12:45
I don't believe you have to but it probably wouldn't hurt seeing the bootloader is so old . The bootloader is like a mini IOS that loads if for some reason the main image doesn't load.It gives you a lot more flexibility in recovering the box instead of it booting into rommon .
