Hypothetical Flash Upgrade
Answered Question
Apr 15th, 2009
  • Bronze, 100 points or more
Ok, so I have a hypothetical scenario that I would like to ask some procedural questions on.
Lets just say that someone was going to go against Cisco's advice and guidelines to be a complete rebel and try to upgrade their very, very small 128MB flash card in theri UC to a 2GB flash card.
What would be the propper procedure in doing so? :)
How should one format the card and get the files onto it, etc...
Thanks!!!
-Brian
Correct Answer by Marcos Hernandez about 7 years 11 months ago
You could use a CF reader and move the files on your PC using Windows Explorer. But the fact is that we do not support or test any other hardware.
Marcos
Overall Rating: 5 (1 ratings)
Correct Answer
Marcos Hernandez Wed, 04/15/2009 - 14:06
  • Blue, 1500 points or more
Marcos
