Pix 506e Configuration Help
Apr 15th, 2009
I'm using a single static IP from Verizon DSL and I'm looking to do the following:
1. Static IP to access a webserver (XXX.XXX.XXX.201)
2. Setup a DMZ zone to allow remote access to our phone system (xxx.xxx.x.2)
3. Allow the office work stations to go out onto the internet
Currently the pix configuration allows for everything on the inside to go out onto the internet.
This is my current pix configuration:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
access-list inside_access_in permit ip any any
access-list inbound permit tcp any interface outside eq www
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside XXX.XX.XXX.XXX
ip address inside XXX.XXX.X.1
ip audit info action alarm
ip audit attack action alarm
pdm location inside
pdm location outside
pdm location XXX.XXX.X.201 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 10 0 0
static (inside,outside) tcp interface www XXX.XXX.X.201 www netmask 0 0
access-group inside_access_in in interface inside
route outside XXX.XX.XXX.X 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http XXX.XXX.X.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address XXX.XXX.X.3-XXX.XXX.X.100 inside
dhcpd dns XX.XXX.X.XX XX.XXX.X.XX
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
