gogasca Wed, 04/15/2009 - 18:32
  • Green, 3000 points or more
Shouldnt be a problem, what exactly you want to deploy.
balitewiczp Wed, 04/15/2009 - 20:16
currently have dedicated gk, and gk controlled trunks connecting 4 different clusters. One of the CM4 clusters has a CM7 cluster running in parallel to which I will be moving all those sites to the CM7. Trying to establish 4digit IC dialing. between this cm4 and cm7 .Since this non gatekeeper controlled trunk is only temporary, am unsure if I could have both. Hope this makes some sense.
r.errington Thu, 03/08/2012 - 06:24
I am trying to configure the same design but use the GK trunks for TEHO but the Gatekeeper does not keep track of the calls (bandwidth) from the GK to the CUCMs that have non GK trunks attached. Everything else works fine so if you realize this limitation you should have no problem.
