04-15-2009 02:16 PM - edited 02-21-2020 03:24 AM
Pls forgive my ignorance, I am fresh in the NAC biz.
I have a requirement from a customer, quite large hospital with many high rising, they want to assign the MDs to the same vlan, whether s/he is using the desktop in the out clinic, which would be Layer-3 OOB, as well as while s/he is using the wireless Tablet PC/PDA during the ward round.
The question is if this is some thing achievable. A little hint how to do it, would be great help.
Appreciate your expertise.
Sami
Solved! Go to Solution.
04-16-2009 12:34 PM
Per user role VLAN can be enabled for OOB.
The VLAN is configured on the role and during the OOB configuration there's a checkbox that you have to enable so the user receives the vlan configured on the role (I don't remember the exact section right now..).
With this, whenever a user that is part of a specific role connects, it will receive the same VLAN according to what's configured on it's role.
Hope this helps.
04-16-2009 12:34 PM
Hope this helps.
