Non Cisco client radios and 1232AG access point problems
airlinkauto
We have two 1232 APs running 12.3(8)JEA software and about 15 USB radios (B/G) made by Via that are having problems staying connected. The problem is very intermittent and is driving us crazy!! We are also seeing an issue with a NetGear PCI card taht's in a PC. We recently disabled all the 802.11G radio settings but didn't see much improvement.
Leo Laohoo
Can you post your config?
Radio Settings:
A radio is off G is on
Wep (short key) is enabled
All OFDM rates are disabled
1,2,5,and 11 mb = Require
CCK Transmit = max
OFDM Transmit = max
Client Power local = Enable
Limit Client Power = Max
Channel is 11 (other AP is 6)
World mode = disable
Country = blank
Preamble = short
Rx and Tx Antennas = diversity (ap has two whips)
External antenna = disable
Traffic stream = disable
Aironet extensions = disable
Ethernet Encapsulation Transform:= RFC1042
Reliable Multicast to WGB: = Disable
Public Secure Packet Forwarding:= Disable
Short Slot-Time: = Enable
Beacon Privacy Guest-Mode:= Disable
Beacon Pd. = 100
Max Data Retries = 64
Frag threshold = 2346
Data Beacon (DTIM) = 10
RTS Max retries = 64
RTS Threshold = 2347
Route Parent Time Out = 0 rest are blank
Security: Global SSID Manager
SSID Interfaces are set for both A and G radios even the A radio is not enabled
Method accepted is Open Authentication with no addition
Server priorities are both at default
Key Mgmt = None
CCKM and WPA are not checked
WPA shared key is blank
Accounting is left at defaults
General settings box--nothing checked everything left blank, disabled or none
Multiple BSSID Beacon Settings box--nothing checked or enabled
Guest Mode/Infrastructure SSID Settings = Single BSSID
Hope this is what you were looking for, let me know if you need anything else.
