Installing IOS
Apr 15th, 2009
trying to install router ios and it freezes
see below
System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 processor with 163840 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library.......
program load complete, entry point: 0x8000f000, size: 0x16474e4
Self decompressing the image : #################################################
############################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X00020000 Crypto module pools
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 9944991 bytes to IO Memory.
PMem allocated: 148897792 bytes; IOMem allocated: 18874368 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(23), R
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 08-Nov-08 20:07 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected]. ***(stops right here)***
anyone have a clue what is the error is.
sorry if its the wrong forum.
Leo Laohoo Wed, 04/15/2009 - 19:12
Stops there? How long have you waited for the next line to appear?
ratewiz21 Thu, 04/16/2009 - 15:38
yes i tried base and broadband ...... broadband gives me an error (invalid ios)
ratewiz21 Thu, 04/16/2009 - 15:01
I have left it running for 48hrs for the next line with no success.
