CallManager 5.x
cris_jimenez
Level 2
Level 2
folks
could you tell me the exact command that I need to issue through the CLI to start the CCM service?
My server is down and I only have access to the CLI
thanks
This problem happens when you have 0% space left on the active partition.
When that happens, services.conf will be corrupted and no service can start.
You may either copy the services.conf from inactive partition or copy it from another working server.
Michael
7 Replies 7
htluo
Level 9
Level 9
Please explain "My server is down".
1) You're not able to see the web page at all?
or
2) You can see the web page but not able to login?
If it's #1, then Tomcat is down. You should use "utils service list" to see if Tomcat is runnig.
If it's #2, please let us know what error message you're getting. If you got "wrong username/password", it could be password mistyped. If you got "IMS exception" it could be DB issue.
From my experience, if "my server is down", you won't be able to fix it just by starting CallManage service from CLI (I wish it was that easy). :)
Michael
I don't know what happened, when I rebooted the server and the services didn't start
admin:utils service list
Requesting service status, please wait...
System NTP [STARTED]
System SSH [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
Cisco AXL Web Service[STOPPED] Service Not Activated
Cisco Bulk Provisioning Service[STOPPED] Service Not Activated
Cisco CAR Scheduler[STOPPED] Service Not Activated
Cisco CAR Web Service[STOPPED] Service Not Activated
Cisco CTIManager[STOPPED] Service Not Activated
Cisco CTL Provider[STOPPED] Service Not Activated
Cisco CallManager[STOPPED] Service Not Activated
Cisco CallManager Attendant Console Server[STOPPED] Service Not Activated
Cisco CallManager SNMP Service[STOPPED] Service Not Activated
Cisco Certificate Authority Proxy Function[STOPPED] Service Not Activated
Cisco DHCP Monitor Service[STOPPED] Service Not Activated
Cisco Dialed Number Analyzer[STOPPED] Service Not Activated
Cisco DirSync[STOPPED] Service Not Activated
Cisco Extended Functions[STOPPED] Service Not Activated
Cisco Extension Mobility[STOPPED] Service Not Activated
Cisco IP Manager Assistant[STOPPED] Service Not Activated
Cisco IP Voice Media Streaming App[STOPPED] Service Not Activated
Cisco Messaging Interface[STOPPED] Service Not Activated
Cisco SOAP - CDRonDemand Service[STOPPED] Service Not Activated
Cisco Serviceability Reporter[STOPPED] Service Not Activated
Cisco TAPS Service[STOPPED] Service Not Activated
Cisco Tftp[STOPPED] Service Not Activated
Cisco WebDialer Web Service[STOPPED] Service Not Activated
Primary Node =false
Doing more reseach I found this on the logs
04/15/2009 18:23:21.976 ServM|servMProcShell: Client Port : 8889|<:SERVMID><:BHUSDCM2><:DETAILED><:0010>
04/15/2009 18:23:30.014 ServM|servMXmlParser - ActivateConf : NULL Document
04/15/2009 18:23:30.014 ServM|Failure to read /usr/local/platform/conf/services.conf|<:SERVMID><:BHUSDCM2><:DETAILED><:0010>
04/15/2009 18:23:30.046 ServM|Sucessfully read
I had to go with cisco to get a root account and replace the services.conf
Michael
this was our case, the active partition disk utilization was 100% we tried to release some through RTMT however that wasn't working. the space available on the active partition is 9% I need to figure a way to delete the traces and log files form the servers. I will have to get back with cisco, because the RTMT tool isn't working
thanks
Was this on publisher or subscriber box.... been having similar problem on subscriber.
I have exact same problem on subscriber CUCM 5.1.1.
my services wont start after restart CUCM.
>> Return code = 0
Primary Node =false
Activelog disk is 93% full.
I have deleted almoust 5 GB of logs from Activelog disk (deleted from CLI) and restart CUCM, but still 93% disk full ?!
Please help...what do do?
Alen
