Strange failure for WLC in RME (4.1.1) archive config
Apr 15th, 2009
Hi Experts,
I got this strange failure for WLC in RME archive config (LMS 3.0)
fig from device: java.net.SocketTimeoutException: Read timed out fig from device: java.net.SocketTimeoutException: Read timed out
Please advise.
Thanks and Regards,
Yi Shyuan
Joe Clarke Wed, 04/15/2009 - 19:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What protocol are you using the fetch the config from the WLC (telnet or SSH)?
jeeyishyuan Wed, 04/15/2009 - 19:26
Hi Joe,
I am using both with Telnet as highest priority and SSH lower.
Joe Clarke Wed, 04/15/2009 - 19:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
But what protocol should work to fetch the config?
jeeyishyuan Wed, 04/15/2009 - 20:58
Hi Joe,
Telnet should be the correct one.
Anyway, I have figured out the solution. It's due to authentication priority is not correctly set in WLC and the credentials that I have used is only for read access. Hence, the config archive failed.
Thanks and Regards
Yi Shyuan
