04-15-2009 06:38 PM - last edited on 03-25-2019 05:42 PM by ciscomoderator
Hello Pro,
I plan to upgrade two PIX525(Active/FO mode) 6.3 to 8.0 The current flash:16M,memory:256M.
I'd like to know the followings:
1. Do I need to upgrade flash and memory card;
2. How do I get ur license and fo license
3. May I upgrade from 6.3 to 8.0 directly, or I need to upgrade to middle version 7.x at first and then proceed to 8.0
It's an upcoming issue, would you please give me some advice on this issue?
Thank you!
04-15-2009 08:00 PM
Le, go over bellow links to get you started on assesment,all your questions are answered there ...
No , you seem to meet requirements, 16F and 256RAM minimum is required for ur and fo.
Whatever active license is running under 6.x will carry over onto 7.x/8.x
my suggestion is to upgrade to a GD release in the 7.x train first.
http://www.cisco.com/en/US/docs/security/asa/asa70/pix_upgrade/upgrade/guide/pixupgrd.html
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708d8.shtml
04-21-2009 10:36 PM
maybe this one is usefull to you:
http://www.cisco.com/en/US/docs/security/pix/pix80/release/notes/prn803.html
Johan
