Asa 5505 outside cant access server in the inside
Answered Question
Apr 15th, 2009
hi, i have an Asa 5505, a pc in the outside with the ip 10.1.1.6 cant access to a server in the inside 192.168.1.4, pls help...
this is my conf:
ASA Version 8.0(4)
hostname ciscoasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 0
interface Vlan2
nameif outside
security-level 0
ip address 10.1.1.2 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa804-k8.bin
ftp mode passive
dns server-group DefaultDNS
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list 100 extended permit tcp any host 10.1.1.3 eq www
pager lines 24
logging enable
logging asdm debugging
mtu inside 1500
<--- More --->
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-613.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 10.1.1.3 192.168.1.4 netmask 255.255.255.255
access-group 100 in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
<--- More --->
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
<--- More --->
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:14e7b74fabc386613ae646b915f60e9e
: end
ciscoasa#
Correct Answer by vikram_anumukonda about 8 years 3 months ago
got it , but is anything showing up in the logs when you try to access 10.1.1.3 over http
Overall Rating: 5 (1 ratings)
andresfmg Thu, 04/16/2009 - 05:16
yes is an error the security-level actually is on 100 right now. but still not work.
any other idea ?
vikram_anumukonda Thu, 04/16/2009 - 05:38
  • Bronze, 100 points or more
don't you need to exempt .4 from DHCP range. logging might be helpful here.
andresfmg Thu, 04/16/2009 - 05:46
from the outside i try to access 10.1.1.3, then the nat translate to 192.168.1.4 thats the idea becouse from outside cant access directly to 192.168.1.4
Correct Answer
vikram_anumukonda Thu, 04/16/2009 - 07:58
andresfmg Fri, 04/17/2009 - 05:26
wrong configuration in the server.
wrong ip on gateway,
