Asa 5505, the outside cant access to a server in the inside
Apr 15th, 2009
hi, i have an Asa 5505, a pc in the outside with the ip cant access to a server in the inside, pls help...
this is my conf:
ASA Version 8.0(4)
hostname ciscoasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
interface Vlan1
nameif inside
security-level 0
ip address
interface Vlan2
nameif outside
security-level 0
ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa804-k8.bin
ftp mode passive
dns server-group DefaultDNS
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list 100 extended permit tcp any host eq www
pager lines 24
logging enable
logging asdm debugging
mtu inside 1500
<--- More --->
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-613.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1
static (inside,outside) netmask
access-group 100 in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
<--- More --->
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
<--- More --->
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
: end
Jon Marshall Thu, 04/16/2009 - 03:46
The security level for your inside interface should be 100 ie.
interface Vlan1
nameif inside
security-level 100
ip address
After changing that can you
1) ping the outside interface of the ASA from the pc or ping the PC from the ASA
2) I'm assuming you are trying to connect to when you attempt the connection ?
andresfmg Thu, 04/16/2009 - 05:15
yes is an error the security-level actually is on 100 right now. but still not work.
any other idea ?
