Topology map not working in LMS 3.1
Apr 15th, 2009
I recently did a clean installation of LMS 3.1. The topology services is not working returning an error named "Failed to initialize: Java.lang.NumberFormatException: null"in the pop up window.
Any help would be appreciated
with thanks
Overall Rating: 4 (1 ratings)
Pari Thiagasundaram Wed, 04/15/2009 - 20:21
Use only the recommended Java version 1.6.0_05.
Go to the Start > Settings > Control Panel. Double-click on the Java
Plug-in icon. Go to the Cache tab and click "Clear".
Hernan Moya Thu, 06/10/2010 - 13:23
I can't unse this version of java plug-ins because in a screen of Campus
Manager said you need to install java 1.5. I deinstalled all plug-ins of Java of my notebook an then install only plug-ins that LMS 3.1 have jre-1_5_0_15-windows-i586-p_withvbj.exe
Only with this plug-ins, Topology map is working now.
