%C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE:
Apr 15th, 2009
Hi NetPro,
i got this major problem. anyone can help ?
Apr 16 03:49:39.621: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 2 times)Unable to determine whether to route or bridge replicated softwar
e-processed packet with source address 00:16:E6:0E:D7:C2 and destination address 00:00:0C:07:AC:64
.Apr 16 04:17:39.994: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: Unable to determine whether to route or bridge replicated software-processed packet w
ith source address 00:1A:4D:DF:7C:EB and destination address 00:00:0C:07:AC:64
.Apr 16 05:53:05.692: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 5 times)Unable to determine whether to route or bridge replicated softwar
.Apr 16 06:08:11.778: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 2 times)Unable to determine whether to route or bridge replicated softwar
e-processed packet with source address 00:15:58:E6:23:F3 and destination address 00:00:0C:07:AC:64
.Apr 16 10:32:45.192: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 1 times)Unable to determine whether to route or bridge replicated softwar
e-processed packet with source address 00:1A:4D:DF:7D:7D and destination address 00:00:0C:07:AC:64
.Apr 16 11:21:56.283: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 2 times)Unable to determine whether to route or bridge replicated softwar
.Apr 16 11:33:41.296: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 8 times)Unable to determine whether to route or bridge replicated softwar
.Apr 16 11:49:29.607: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 14 times)Unable to determine whether to route or bridge replicated softwa
re-processed packet with source address 00:1A:4D:DF:79:A8 and destination address 00:00:0C:07:AC:64
.Apr 16 12:00:55.324: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 4 times)Unable to determine whether to route or bridge replicated softwar
.Apr 16 12:11:52.200: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 8 times)Unable to determine whether to route or bridge replicated softwar
e-processed packet with source address 00:15:58:E0:B3:66 and destination address 00:00:0C:07:AC:64
thanks.
Overall Rating: 2 (1 ratings)
Leo Laohoo Wed, 04/15/2009 - 21:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
From: http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/system/messages/emsg.html
When a replicated packet is sent to the software by an output ACL, the hardware does not indicate whether the packet needs to be bridged or routed.
When resources are exhausted or when the ACLs programmed in the hardware cannot handle processing directly (such as ACLs matching TCP flags), the Supervisor Engine III sends the packets to software for processing. If the software cannot determine whether to bridge or route, the packet might be dropped. This drop indicates that the packet was directed to a Hot Standby Routing Protocol (HSRP) router group MAC address.
This is an informational message only. No action is required.
ney25 Thu, 04/16/2009 - 00:41
Hi Leolaohoo.
thanks for your information, basically i got that info from cisco msg decoder as well. but i was just thinking if the sup engine is busying for these msg it will use a lots of the cpu proc , then it will hit to the high cpu utilization soon... isn't it ?
your reply will be highly appreciated.
thanks.
Leo Laohoo Thu, 04/16/2009 - 04:04
  • Hall of Fame,
    2017 LAN, Wireless
That depends on your IOS, configuration and your network. Try doing "sh processor cpu history" just to make sure.
tumbulina Tue, 09/29/2009 - 07:45
Hi All,
I'm having the same problem here. From what I've seen, this is an informational message but, does anyone know if it's possible not to have this message logged on the syslog server ?
Mary
Lucien Avramov Tue, 09/29/2009 - 09:09
  • Red, 2250 points or more
Check if you also see messages such:
C4K_L3HWFORWARDING-3-FWDCAMCONSISTENCYCHECKFAILED
If those appear quite often, you may have a hardware failure.
