what is a forward metric 2 in "show ip route"
Apr 15th, 2009
Hi all,
I wonder what is a "forward metric"
SG1#sh ip route 100.1.13.0
Routing entry for 100.1.13.0/24
Known via "ospf 10", distance 110, metric 20, type extern 2, forward metric 2
Last update from 100.1.7.9 on FastEthernet5/1/0, 1w2d ago
Routing Descriptor Blocks:
* 100.1.1.9, from 100.100.100.1, 1w2d ago, via FastEthernet1/0/0
Route metric is 20, traffic share count is 1
100.1.3.9, from 100.100.100.1, 1w2d ago, via FastEthernet3/0/0
100.1.7.9, from 100.100.100.1, 1w2d ago, via FastEthernet5/1/0
in above text,
I don't know about forward metric 2
anyone knows about this??
thotsaphon Thu, 04/16/2009 - 00:21
  • Gold, 750 points or more
Sanghee,
The forward metric is the cumulative costs from this router to ASBR. You are seeing O*E2 routes. If you changed to O*E1 then you will see the metric as metric 22(20+2). You won't see the forword metric value when using "type extern 1".
HTH,
Toshi
