LMS 3.1 back-up error - space is not enough
Apr 16th, 2009
I have a LMS3.1 instalation that has arround 2500 devices in the DCS. I want to make a back-up of the database every week but i gat an error that is not enough space. Ok i understand this but the space that it requires is huge (arround 60GB)
I use only RME, CM and IPM and keep reports, logs etc..only for one month.
What could be the problem? Is this normal?
Sven Hruza Thu, 04/16/2009 - 05:53
Perhaps you have some huge logfiles?!?
That is not impossible on a LMS server ;-)
I think the best way is to look on your server for big files with a freeware tool such like "Primitive File Size Chart" or something like this.
i.cristian Thu, 04/16/2009 - 06:07
Thanks for reply
The entire log directory is 2,4 Gb so is not so big.
Sven Hruza Thu, 04/16/2009 - 06:12
Are there other huge files on the server which will be backuped?
i.cristian Thu, 04/16/2009 - 06:16
i do not think there are another huge files. Logs should be the bigest files.
Where should i look for?
Entire CSCopx direcory has 12 GB..
yjdabear Fri, 04/17/2009 - 10:36
What platform is your LMS on? If on Solaris, check the size of /var/adm/CSCOpx/files, specifically /var/adm/CSCOpx/files/rme/dcma/difffiles. If on Windows, do a search for difffiles and look both up and down the folder hierarchy.
i.cristian Mon, 04/20/2009 - 23:15
The platform is Windows.
The Difffiels directory is on a separate partition and it has 1.3 Gb and 24k files. Also i have a Devfiles directory with 1Gb and 11k files.
I agree that the number of files is big but the entire space occupied is not so big.
Any other ideas?
