stacking 2975 switches
Apr 16th, 2009
Hi all, If I simply plug in my stack cables to my switches, will they work as one stack without any config?
also what is the minimal config i need to put on for stacking,how would I assign an IP to the stack ?
Overall Rating: 4 (2 ratings)
Leo Laohoo Thu, 04/16/2009 - 04:03
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Carl,
Configure the stack master like the way you configure any switch. Regarding the stack, it behaves just like a 3750.
carl_townshend Thu, 04/16/2009 - 05:03
what commands do I need to know for the stacking then? how do I know which is master, and how do I force one to be master?
if I replace or add a switch, will it automatically add it ?
what commands do I need to know for the stacking then? - none really
how do I know which is master - show switch, highest priority is master switch
how do I force one to be master - change switch priority - switch # priority in config mode
if I replace or add a switch, will it automatically add it - yes
carl_townshend Thu, 04/16/2009 - 06:23
Hi,how would I know which switch is which, when I do show switch, would it show the serial numbers and stack number? also will any lights come on at the front of the switch ?
If you have configured each switch prior to stacking - an example output would look like:-
#show switch
Switch/Stack Mac Address : 0022.5635.1600
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master 0022.5635.1600 15 0 Ready
2 Member 0022.5650.6e00 10 0 Ready
3 Member 0022.5656.4c00 5 0 Ready
From the front of the switches you toggle the "mode" button down to the "Stack" mode and each switch will blink there number in the stack from the firat 1-9 ethernet ports.
The master switch will blink port 1 - the second switch will blink port 2 etc.
