WCS Downgrade Question
Apr 16th, 2009
I have a WCS running and with the changes made for Lobby Ambassadors, I would like to downgrade to 4.x.x.x.
Is the process straight forward, as I know you can do a backup and then restore - will this work with older versions?
Any help/guides will be greatly appreciated.
Many thanks
ericgarnel Thu, 04/09/2009 - 09:06
The upgrade process adds several database tables; not sure if installing an older version of WCS would strip them out. There is the possibility of the downgrade corrupting the db. You may want to open a TAC case and inquire about it.
The 2 feasible options would be to either do a fresh install of the desired version and restore a pre 5.x db backup, or just start all over with a fresh 4.x.x.x. install
You could also try building a test machine with 5.x, make a backup from the production wcs server and restoring it to the test machine and see what happens when you try to downgrade to 4.x.x
miomalle Thu, 04/16/2009 - 23:55
Hi Eric,
Thanks for that information.
Just to satisfy my curiosity, I upgraded my WCS to version 5, took a backup and downgraded back to version 4 just to check if it would work - but no, it refused to restore from a newer version. I saved a copy of the v4 database which restored fine.
I wonder if anyone knows of a work around?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
