Cisco Unity Connection 7.0.1.11000-2 IVR
Apr 16th, 2009
hi,
I have an IVR prompt in place and it works.It plays greeting like
press 1 for sales inturn hardcoded to 5001
press 2 for presales inturn hardcoded to 5002
press 3 for hr inturn hardcoded to 5003
The Challenge is here , Customer wants to have an option wherein it asks calling party for known extensions like
press 4 for known extensions
If a calling party hits 4 ,then IVR should play greeting like press known extension,then it should listen to the input , then match to that exact extension number.
i tried this in caller input under system call handlers but it did not workout.Its not accepting any wildcard digits.
Can you guys guide me here out pls..
shiv..
Jaime Valencia Thu, 04/16/2009 - 07:31
  • Cisco Employee,
  • Hall of Fame,
    2011
by default you can dial any extension (that exists in CUC) while the greeting plays as long as you don't lock the keys under caller input
ie if you have it right now with locked keys only DNs starting with 0, 4-9 would work
why don't you simply record "if you know your party's extension dial it anytime during the greeting, for sales pres..."
java
if this helps, please rate
