Logger Unable to Start
Apr 16th, 2009
Receiving the following error in Event Viewer: Fail Connection to SQL Server Failed Event ID: 49155 and Event ID: 49158
The AW also cannot connect more than likely tied to the Logger not starting.
joesnyde Thu, 04/16/2009 - 06:54
  • Cisco Employee,
Ensure there is connectivity between the logger process, SQL Server and the domain controller. Specifically check for connectivity to Active Directory servers for login access.
Event ID: 49158
Verify DNS and WINS are correctly setup on the logger.
Check your NIC binding order, Visible first then private.
karnakumar Sun, 12/06/2009 - 16:33
It's normaly due to domain group policy settings. Add ICM service accounts in domian group security policy in domian controller, under "log on as a service" add these accounts.
