LMS 3.0.1 CM 5.0.4 Cisco 6509 Switch VSS
Joe Clarke Thu, 04/16/2009 - 09:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
VSS support is not available until Campus Manager 5.1, so you will need to upgrade to LMS 3.1 to get support for this device in Campus. For CiscoView, make sure you have Cat6000IOS package version 30.1, and the switch will be supported.
You can update your CiscoView packages under Common Services > Software Center > Device Update.
