SSLM optimistic connection handling?
Apr 16th, 2009
If this is posted in the wrong place please let me know.
The behaviour seen in the CSM/SSLM setup we're using indicates that the SSLM is being optimistic about the authentication process and initiating the clear connection before it's completed the certificate authentication.
Is there a way to disable this connection handling so that it only initiates the clear connection when it has successfully completed the SSL authentication?
Thanks!
