Restore takes forever
Apr 16th, 2009
I'm attempting a restore of a fresh install MARS 50 6.0.2. The restore process have been stuck at
"Invoking binary config importing procedure ...
Checking schema ...
Recreating the database schema.
Importing data into database ...
for the last 4 hours and the Oracle is running at 80%+ CPU. I'm only doing a config restore and the previous MARS 50 had only been running for some 4 months.
I've done a few restores of earlier versions and never had any problems. Anyone seen this before?
Fredrik
ivillegas Wed, 04/22/2009 - 07:38
Backups may be confused when someone start archiving a new MARS-50 at 6.0.2 in the same directory as the old backups.
So separate out the invalid data from the valid.
