AnyConnect MTU Size
Apr 16th, 2009
Going through the release notes for AnyConnect 2.3 it gives the example that the MTU size is set to 1406 bytes just after Figure 11, but includes no explanation. Is this just an example of how to change the MTU size or is this a recommendation for optimal performance?
Does anyone know?
smalkeric Wed, 04/22/2009 - 07:42
  • Silver, 250 points or more
You can adjust the Maximum Transmission Unit size (from 256 to 1406 bytes) for SSL VPN connections established by the AnyConnect Client by using the svc mtu command from group policy webvpn or username webvpn configuration mode:
[no] svc mtu size
This command affects only the AnyConnect Client. The Cisco SSL VPN Client (SVC) is not capable of adjusting to different MTU sizes.
The default size for this command in the default group policy is 1406. The MTU size is adjusted automatically based on the MTU of the interface that the connection uses, minus the IP/UDP/DTLS overhead.
This command affects AnyConnect Client connections established in SSL and those established in SSL with DTLS.
The following example configures the MTU size to 1200 bytes for the group policy telecommuters:
hostname(config)# group-policy telecommuters attributes
hostname(config-group-policy)# webvpn
hostname(config-group-webvpn)# svc mtu 1200
