Connect Pbx and Data Network Through 2811
Apr 16th, 2009
I'm new in Cisco. I have 2811 router with VWIC-1MFT-E1 and I want to connect 2 different network to it (data & voice).
eg.
Data&Voice----->2811---->E1----->2811---->Data&Voice
my question is :
At first I'm connect the VWIC-1MFT-E1 to Pbx. The system is working fine. But when I'm connect the 10/100 Fast Ethernet ports to Data network, the Pbx start going intermittent. Can you help me how to solve this ? Is my config is wrong ?
tq
paolo bevilacqua Thu, 04/16/2009 - 09:46
  • Hall of Fame,
    Founding Member
Have you set clock source internal for the PBX E1 ?
farozezan73 Thu, 04/16/2009 - 20:47
According to my Pbx vendor, there's nothing wrong with clock. Because the pbx is working fine. For ref. pls find the attached config.
paolo bevilacqua Fri, 04/17/2009 - 06:15
  • Hall of Fame,
    Founding Member
Please send text only attachments to make it easier.
farozezan73 Fri, 04/17/2009 - 21:02
the config :
Current configuration : 3544 bytes
version 12.4
service timestamps debug datetim
hostname ROUTER_BKE-TP
boot-start-marker
boot-end-marker
enable password pr0p3l
no aaa new-model
network-clock-participate wic 2
ip cef
no ip domain lookup
isdn switch-type primary-qsig
voice-card 0
no dspfarm
voice call carrier capacity active
voice service voip
signaling forward rawmsg
sip
voice class codec 1
codec preference 2 g711ulaw
archive
log config
hidekeys
controller E1 0/2/0
pri-group timeslot
interface Loopback0
ip address 10.192.1.28 255.255.255.255
interface FastEthernet0/0
description Connect to PBX
ip address 172.16.4.2 255.255.255.0
shutdown
duplex auto
speed auto
interface FastEthernet0/1
description Connect to CAT3750E BKE
ip address 10.192.33.9 255.255.255.252
duplex auto
speed auto
interface Serial0/1/0
description Connect To TM Leased Line
bandwidth 2048
ip address 10.192.33.6 255.255.255.252
ip tcp header-compression i
auto qos voip
service-policy output AutoQoS-Policy-UnTrust
ip rtp header-compression iphc-format
ip rsvp bandwidth 1024 1024
router eigrp 101
network 10.0.0.0
network 192.0.0.0
network 200.1.2.0
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
dial-peer voice 1 voip
description ROUTER_BKE-TP to ROUTER_BRT-RCC
destination-pattern ....
session protocol sipv2
session target ipv4:10.192.1.29
req-qos guaranteed-delay
codec g711ulaw
dial-peer voice 2015 pots
description ROUTER_BKE-TP to PBX_BKE-TP
direct-inward-dial
port 0/2/0:15
forward-digits all
gateway
timer receive-rtp 1200
sip-ua
reason-header override
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
exception data-corruption buffer truncate
scheduler allocate 20000 1000
end
paolo bevilacqua Sat, 04/18/2009 - 07:02
  • Hall of Fame,
    Founding Member
Under controller E1 0/2/0 configure:
farozezan73 Tue, 04/21/2009 - 03:02
I've done the config but still can't. Do I need to config both router ? And is my previous config is correct ?
paolo bevilacqua Tue, 04/21/2009 - 03:06
  • Hall of Fame,
    Founding Member
Send a corrected network diagram because the one aboe doesn't really make sense.
farozezan73 Wed, 04/22/2009 - 06:22
PBX---2811---E1 Leased Line---2811---PBX
*both 2811 router connected to CAT3750E for Data Network
ROUTER_BKE-TP#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ENTSERVICESK9-M), Version 12.4(19b),
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 13-Jun-08 04:12 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
ROUTER_BKE-TP uptime is 11 weeks, 1 day, 2 hours, 16 minutes
System image file is "flash:c2800nm-entservicesk9-mz.124-19b.bin"
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FHK1242F1JU
2 FastEthernet interfaces
13 Serial interfaces
1 Serial(sync/async) interface
1 Channelized E1/PRI port
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
sh run :
controller E1 0/2/0
pri-group timeslot
interface Loopback0
duplex auto
speed auto
bandwidth 2048
auto qos voip
interface Serial0/2/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn overlap-receiving
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
isdn outgoing display-ie
no cdp enable
router eigrp 101
network 10.0.0.0
network 192.0.0.0
network 200.1.2.0
no auto-summary
ip http server
codec g711ulaw
direct-inward-dial
port 0/2/0:15
forward-digits all
gateway
sip-ua
paolo bevilacqua Wed, 04/22/2009 - 10:34
  • Hall of Fame,
    Founding Member
You cannot have the same destination-pattern .... for both pots and voip DP. Configure them correctly accordingly to the numbers in use.
You also need to configure incoming called-number for both DPs.
farozezan73 Thu, 04/23/2009 - 17:51
Configured already but still can't. My config :
dial-peer voice 2 voip
destination-pattern 16..
destination-pattern 10..
Sorry, but is it because of the pri-group timeslots below ? It should be 32 ts right ?
controller E1 0/2/0
pri-group timeslots 1-12,16
tq
farozezan73 Fri, 04/24/2009 - 18:11
According to the pbx vendor the destination pattern should be :
destination pattern ....
as the pbx will forward the number to router.
paolo bevilacqua Sat, 04/25/2009 - 01:15
  • Hall of Fame,
    Founding Member
Let the PBX vendor care about the PBX only,
You need a proper configuation of the routers or nothing will work. I recommend you hire a reputable partner for that.
farozezan Wed, 04/29/2009 - 06:43
But when I try to enter the
command "pri-group timeslots 1-31" under the E1 controller I
get this error:
% Not enough DSP resources available to configure pri-group on controller E1 0/0/0
% The remaining dsp resources are enough for 0 time slots.
% For current codec complexity, 2 extra dsp(s) are required to create this voice port.
Is it true that's why my network is intermittent.
