7200 VXR router
Apr 16th, 2009
is the nvram in NPE-400 or on the I/O controller in 7200 Vxr router
Giuseppe Larosa Thu, 04/16/2009 - 06:58
Hello Vaibhav,
if you are planning to upgrade to NPE-G1 or better you need to backup the config file.
in older processors they look for NVRAM on I/O controllers but NPE-G1 can work without an I/O controller so it has its own NVRAM
So the config file should be on I/O controller with an NPE 400
Hope to help
