Need help changing IP's & CCM
Apr 16th, 2009
I'm running UCCE 7.0 and I need some help on moving to a different IP network and CCM. As far as I know, I need to recreate the Route Points, peripherals and JTAPI interfaces on the new CCM, but I don't know what else I need to do to change the IP configuration on the components. Is it as simple as running ICMSETUP.exe? I'm limited on what I can do since I only have a production duplexed system. I can afford to take an IVR and the B side down, but I cannot shut down the entire system.
