How to segregate NAT ACL on Cat65K
cisco_lite
There are three vlans on the core switch, VLAN 15,16,17
The traffic going from VLAN 15 into VLAN 16/17 should be NAT'ed. So VLAN 15 has ip nat inside and VLAN16/17 has ip nat outside. NAT is working fine from VLAN15 into VLAN16 with 'ip nat inside source static x x'.
How can I define the NAT'ed ip list for VLAN17 because I want to NAT the same source IP to a different IP when going into each of the other VLANs. I believe 'ip nat inside source' will not allow the same source ip to be natt'ed to different ip based on the destination VLAN.
How can this be achieved.
Thanks.
Okay, try this -
vlan 15 = 192.168.5.0/24
vlan 16 = 192.168.10.0/24
vlan 17 = 192.168.11.0/24
access-list 101 permit ip 192.168.5.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 102 permit ip 192.168.5.0 0.0.0.255
192.168.11.0 0.0.0.255
ip nat inside source static 192.168.5.10 172.22.1.1 route-map PNAT1 extendable
ip nat inside source static 192.168.5.10 172.22.1.2 route-map PNAT2 extendable
route-map PNAT1 permit 10
match ip address 101
route-map PNAT2 permit 10
match ip address 102
Note i have used 172.22.1.x addresses for NAT, obviously you need to substitute with what you have.
Jon
7 Replies 7
Jon Marshall
Do you need to use static NAT entries ?
The easiest thing to do would be to use PAT on the vlan 16 & vlan 17 interfaces ie.
ip nat inside source list 101 interface vlan16 overload
ip nat inside source list 102 interface vlan17
overload
If you do need static NAT then obviously ignore the above :-)
Jon
Yes, I need to use static NAT. I was facing some other issues with PAT.
Can I use something like policy based NAT'ing etc.
Okay, try this -
Jon
John,
I just wanted to thank you for all your helpful posts, and this one was another learning deal for me. I learn quite a bit from Pros like yourself
Steven
Many thanks for your kind words.
Jon
Thanks John.
One more on the same...Is it correct that usage of route-map does not necessitate applying 'ip policy' on the interface.
"Is it correct that usage of route-map does not necessitate applying 'ip policy' on the interface"
Correct, here is a copy of the config i used to test setup -
interface Loopback10
ip address 10.5.1.20 255.255.255.0
interface FastEthernet0/0
ip address 192.168.5.5 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.5.1 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet1/0
ip address 172.16.5.1 255.255.255.0
ip nat inside
duplex auto
speed auto
router eigrp 1
network 10.0.0.0
network 172.16.0.0
network 192.168.5.0
no auto-summary
ip forward-protocol nd
ip http server
ip nat inside source static 172.16.5.2 10.5.1.1 route-map PNAT extendable
ip nat inside source static 172.16.5.2 10.5.1.2 route-map PNAT1 extendable
access-list 101 permit ip host 172.16.5.2 host 172.16.6.2
access-list 102 permit ip host 172.16.5.2 host 172.16.7.2
route-map PNAT permit 10
Jon
