Can I Bond two T1s that are not in the same slot?
Answered Question
Apr 16th, 2009
I have a Cisco 1841. I'm curious to know if you can bond T1s together that aren't in the same slot.
Overall Rating: 5 (2 ratings)
jason.aguero Thu, 04/16/2009 - 09:44
thotsaphon provided a GREAT example, do you have any other sample config that I may be able to use? I just like to maybe have a back up plan.
Any assistance is great.
jason.aguero Thu, 04/16/2009 - 08:48
I have a main site and a remote site that are connected to share bandwidth.
I have a 1841 at the remote site. There is a free slot in the Cisco 1841 at the remote site. I think I can add up to two more T1s in the open slot. Is this correct?
Slot 0: empty
Slot 1: Contains a WIC with two T1 connections.
I have a Cisco 2800 at the main site with multiple slots open.
I am trying to add more bandwidth to the remote site.
Any assistance?
thotsaphon Thu, 04/16/2009 - 08:57
Jason,
Cisco1841 has 2 HWIC slots. So you can add another card on slot0. Are you going to implement Multilink?
Toshi
jason.aguero Thu, 04/16/2009 - 09:02
yes, PPP Multilink.
Any idea how I could set this up? Will I be able to bond the T1s on both slots.
thotsaphon Thu, 04/16/2009 - 09:14
Jason,
You can set it up(both sides). Here is an example.
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/1/0
framing esf
linecode b8zs
interface Multilink1
ip address 1.1.1.1 255.255.255.252
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial0/0/0:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial0/1/0:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
Will I be able to bond the T1s on both slots? Don't worry too much. It can.
HTH,
Toshi
jason.aguero Thu, 04/16/2009 - 10:01
Thanks for your last response, that was QUICK!
By chance would you have another sample (you can leave out the T1 config portion)?
I just always like to have a backup plan?
