LMS 3.1 Netconfig Job is stuck in Cancelling state
Apr 16th, 2009
I ran a netconfig job to add some AAA lines to some of my devices. It got stuck on a 2811 router. It entered the commands successfully, but the job status never updated properly. I tried canceling the job back on April 7th and it's still sitting in the Cancelling state. If I look at the job in CS->Server->Admin->Job Browser, it says the job completed on Dec 31st, 1969 at 18:00:00 hours. How can I get this job to cancel/stop or delete it?
Joe Clarke Thu, 04/16/2009 - 09:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You are most likely seeing one of three possible bugs:
CSCsx24218
CSCsv95235
CSCsw88378
A patch for all three is available by contacting the TAC. As for getting rid of this job, if you run pdshow, and you see a daemon corresponding to the job ID, run:
pdterm ID
For example:
pdterm 1101
That should stop the job. If that doesn't work, you will need to get the instructions from TAC to purge the job from the database.
