Unity Connection 7.x External SMTP access to Exchange
Apr 16th, 2009
  • Green, 3000 points or more
Anyone configure this yet? Im trying to figure out how it authenticates. It says if the CUC alias is the same the Exchange alias, it will work, but I highly doubt it works that way without a password for IMAP to login into correct?
http://cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag295.html
Ginger Dillon Thu, 04/16/2009 - 14:38
  • Blue, 1500 points or more
Hi Tommer -
Sorry for asking the question to confirm, but your post refers to SMTP access and the link you posted takes you to "Configuring Access to Emails in an External Message Store". Did you want TTS access or SMTP notification to user's email? I have implemented TTS in Unity Connection using Exchange 2003 but not tested SMTP notification yet.
Ginger
Tommer Catlin Thu, 04/16/2009 - 17:34
Apparently, if you provide the IMAP connection to Exchange it will read your emails to you through the tui.
