VPN Client w/ Certificate Authentication Issue
Apr 16th, 2009
I have a client that is unable to connect via Cisco VPN IPSEC Client to a ASA. We use Certificate Authentication. Basically the client disconnects after authentication information is entered. There are no issues connecting via AnyConnect to same ASA using the same authentication methods. The VPN Connection Log is attached.
Ivan Martinon Fri, 04/17/2009 - 07:10
Can you please post your ASA config along with the following debugs?
debug crypto isakmp 15
debug crypto ipsec 15
debug crypto ca messages
ANANT SHAH Fri, 04/17/2009 - 07:15
Thanks for your reply. Strangely i am not able to reproduce the problem this morning. I will try for next few days and collect the logs if run into the issue.
