Accounting - Logging commands entered
Apr 16th, 2009
How do you log commands entered by a user connected via telnet. AAA server is ACS, and AAA client is a Cisco Switch
Jagdeep Gambhir Thu, 04/16/2009 - 10:09
To logs commands you need to set up tacacs command accounting.
Here are the command you need to switch
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
These logs would be stored at Tacacs administration report.
If you are running 4.1.1. code on acs then please apply patch 5 to get the command accounting logs.
~JG
Do rate helpful posts
networker99 Thu, 04/16/2009 - 10:14
patch 5?
We are running the build that this should have been fixed in
Jagdeep Gambhir Thu, 04/16/2009 - 13:56
If you are already on software ver released after 4.1.1 patch 5, then no need to bother about it.
